Counter/Timer
The counter/timer pallets for Labview 8?
Having just installed Labview 8 I cannot install the couter/timer pallets I used to work with in LV 6.1 can anybosy give me a pointer on how to proceed?
(3,692 Views)
When you installed version 8, the likelihood is that you also upgraded the version of NI-DAQ at the same time.
Thus you may only now be able to access the DAQmx pallette rathern that the NI-DAQ 6.X, XX functions that you are probably used to.
(3,658 Views)
Hi Gerald-
You will need to installed the Traditional NI-DAQ (Legacy) 7.4.1 driver in order to see the NI-DAQ counter palettes in LabVIEW 8.0.  After you install the driver the palettes will be visible as shown here:
Hopefully this helps-
Message Edited by Tom W [DE] on 04-13-2006 05:24 PM
Tom W
(3,654 Views)
