03-29-2007 07:38 AM
03-29-2007 08:04 AM - edited 03-29-2007 08:04 AM
I believe we figured it out.
The boards were are using have their enable bits set low, and I believe when we have to change or "idle" variable to HIGH to avoid back emf problems through the L296.
As for the question about latching, correct me if I'm wrong, but it looks like it is latched through software. I'm assuming that's what the "idle" variable is for. I'm also assuming that when the task is stopped, the value on the PWM, Dev1/ctr0, is HIGH (10192) or whatever, correct?
I should have posted the setup of our PWM task (we change idel from LOW to HIGH):
void SetupPWM(void)
double frequency = 45;
double duty = 0.0001;
unsigned int idle = 10192; // HIGH is 10192
char *msg = "PWM output on CTR0 OUT is ready. Frequency = 45Hz.";
DAQmxCreateTask("",&pwmHandle);
DAQmxCreateCOPulseChanFreq(pwmHandle, pwmchan, "", DAQmx_Val_Hz,
idle, 0, frequency, duty);
DAQmxCfgImplicitTiming(pwmHandle,DAQmx_Val_ContSamps,1000);
DAQmxStartTask(pwmHandle);
Delay(1/frequency);
InsertTextBoxLine (optionsTab, OPT_TAB_SYSSTAT, ++nlines, msg);
ProcessSystemEvents();
Message Edited by Patrickw on 03-29-2007 08:05 AM
Message Edited by Patrickw on 03-29-2007 08:08 AM
03-29-2007 08:15 AM
Just some guesses:
1. Typically, motor drives will protect the drive transistors from back-emf by putting in dissipative diodes around the output transistors -- these are often referred to as "flyback diodes." After only a quick look at an L296 datasheet, I'm not so sure this chip is designed to handle motor back-emf. This is one thing to look into.
2. You refer to an H-bridge which would makes sense for a bipolar (bidirectional) DC motor drive -- but the L296 appears to me to be unipolar. What's the rest of the circuit you use?
3. I had an app where I had to individually switch the power transistors of a motor drive and one key consideration was the need to guarantee a short delay when switching current direction. This was needed because of the response time of the power transistors themselves. If you were to instantly switch from \ to /, you risk allowing short-circuit conduction straight down one leg | of the H-bridge. That would definitely let some smoke out.
I'm only a LabVIEW progammer, but can follow the main logic of your code and have some ideas.
a. some of the code used to start and stop the pwm task seems redundant. You have several independent if/then's which may cause you to do a start or stop, then later another if/then may cause you to redo or undo it. I think some careful nesting of your logic would be more appropriate.
b. *KEY IDEA* While you stop your pwm task to change duty cycle (may not be strictly necessary, btw), you update the direction bit while pwm is on. I don't see an advantage to this, and it may put you at risk for thought #3 above. I would set the direction bit between the time you stop the pwm and when you restart it.
c. I don't really know what the following line is supposed to do, but it appears that it may not have anything to do with your DAQ tasks. If it does, please explain.
SetCtrlVal(motorTab, MOT_TAB_DIRECTION, cur_direction);
-Kevin P.
03-29-2007 09:49 AM
In response to item 1, I do not believe there are any diode protection for the drive or L296 itself. From what I remember of the board (it's being replaced) is that the diode arrays were protecting the inputs but I don't want to say for sure.
In response to item 2, I'm pretty sure the L296 handles both motor directions. On the schematic, it appears as a pretty standard 4 transistor H-bridge. The board itself, provided by the department, has a four pin breakout (2 direction, 1 enable, 1 GND).
In response to item 3, I thought of that as well. I think what happened was that our enable bit was set to low (there is a PUN though) so when the direction changed, the motor was NOT in high impedance and the resulting back emf created a current surge right through the L296. I think because our counter/PWM was not set to HIGH during the transition, this is what caused our device fail.
For the if statements, I know I could use an XOR set up but I'm not sure how to do that when using data types other than simple logic (TRUE FALSE).
We keep getting errors when we change the duty cycle if we do not stop the task first, I think you may also be correct and we should send the digital write into the if(running). No reason why it should execute each time through unless something changed...
The SetCtrlVal() is simply there to display what is currently written to the bits. We grew tired of using a voltmeter and too lazy to slap in some transistor and LEDS. Well, not lazy, it's just the extra wiring is a bit much on the prototyping board.
Thanks for the info. We should be getting our new H-bridge board in a few hours.
03-29-2007 10:22 AM
Back to your original query: I'm not at hardware to verify, but I'm >95% sure that when you Stop a counter output task, the output will go to idle state. By default, counter idle states tend to be low.
What I'm less sure about is whether the low output state is the same for a running task vs. a stopped task. What I mean by that is that when the task is stopped, it may be that the pin is not *driven* low, but merely floats low with a weak pull-down resistor. If so, then there's a chance external circuitry may override the weak pull-down and cause the state to float high while the task is stopped.
Very speculative on my part, just a couple thoughts that may be useful.
-Kevin P.
03-29-2007 08:14 PM - edited 03-29-2007 08:14 PM
Message Edited by Patrickw on 03-29-2007 08:17 PM
03-30-2007 03:58 PM
Just a friendly thought: I've used DAQmx for some pretty high-intensity apps, and far more often than not, the layer of abstraction it offers has been a significant benefit compared to doing things with raw bit twiddling on a micro. Not trying to talk you out of using the PIC -- you've got a deadline, so do what you gotta do. Just realize that an awful lot of people have managed to successfully use NI boards and DAQmx in a wide range of apps. Granted, there's a non-trivial learning curve getting used to it, and right now you may not have that time to spare.
Have you done any signal checking to answer questions you raised? If you step through your code line-by-line in debug mode, what state is the counter output in when you stop the task? Is it always the same or does it vary from run to run? Are you sure the counter's idle state corresponds to the "OFF" state for the drive circuit?
One last possible tidbit: I know that from LabVIEW, there's a quirk about changing a pulse train's duty cycle. The freq and duty cycle settings get committed when you write to the freq property. If you only write to the duty cycle property, it may not commit. (These rules apply when trying to change freq/duty cycle on the fly. Don't know if they apply in a case like yours with the task temporarily stopped.) There's a chance that your attempts to change duty cycle never "take".
Here's a link. Another one here. One more. And finally... And yes, I agree, that's a DAQmx quirk that's worth grumbling about. Meanwhile, good luck with the PIC.
-Kevin P.
03-30-2007 05:40 PM
04-02-2007 11:16 AM
