Counter/Timer
Reading timestamp from a PXI-6682 has a latency about 60ms. How to reduce that
Justin,
With the latency of 86ms I still cannot get a resolution of 10ms to timestamp the serial ports data. The buffer overflow problem is now resolved, thanks to you and Josh, but I am still not sure how to make my application work.
Thank you very much for you time,
Tihomir
Message 21 of 24
(1,833 Views)
@Justin_E wrote:
If you're just trying to take multiple timestamps off of one signal, take a look at Time Stamp Clock-Cont.VI from the NI Example Finder. To find this example, open LabVIEW and navigate to Help->Find Examples...
Then, make sure the Browse tab is selected, and navigate to Hardware Input and Output -> Timing and Synchronization -> Time-Based -> Time Stamp Clock-Cont.VI
Hi Justin,
I can't find that example in any of my 3 latest versions of LV (2009,8.6 or 8.5.1) do I need a non standard toolkit installed to find it ?
rgds
Justin E
Product Support Engineer
Peter
Message 22 of 24
(1,476 Views)
Hey Peter,
Those examples are included with the NI-Sync driver, available for download at ni.com/support
You can find the latest version (v3.1) here:
http://joule.ni.com/nidu/cds/view/p/id/1367/lang/en
Justin E
National Instruments R&D
Message 23 of 24
(1,472 Views)
Thanks Justin, I think I'll pass on downloading that example since NI-Sync is over 1GB !!  A tad too much overhead for probably 50kB of example code !
rgds
Peter
Message 24 of 24
(1,466 Views)
