Counter/Timer
RESET CI COUNTER EDGE
HOLA COMUNIDAD
ESPERO SE ENCUENTREN BIEN Y ESPERO PUEDAN AYUDARME CON ESTE PROBLEMA
TENGO UN MODULO NI9411 CON EL CUAL ESTOY LEYENDO PULSOS DIGITALES DE UN CONTEO DE INYECCION
EL PROBLEMA SE GENERA YA QUE EL CONTADOR NO PUEDO REINICIARLO
PUES DEBO REALIZAR OPERACIONES Y MOSTRARLE AL OPERADOR EL CONTEO DE LOS PRIMEROS 500 PULSOS
PARA NUIEVAMENTE REPETIR LA PRUEBA Y ASI VOLVER A PONER EL CONTADOR EN 0
ESTOY TRABAJANDO CON LV2016
PERO EL ARCHIVO SE ENCUENTRA CON COMPATIBILIDAD DE LV10
DESDE YA AGRADEZCO SU AYUDA
MUCHAS GRACIAS
(1,735 Views)
Hello osvaldo,
May I ask you to clarify what you want exact perform?
Best Regards.
(1,646 Views)
Hi friend
thanks for answering my question
what I am doing is a code where I read injection pulses but when I need to start a measurement the counter must go to zero and start counting from 0 to 500 pulses
when it reaches 500 pulses the counter must return to 0 and wait again for the authorization to start counting and so on
since it is an automotive fuel injector counter
I appreciate your help in advance
Cheers
(1,621 Views)
