Counter/Timer
Pulse train generation via CTR0OUT with DAQmx?
Hi All,
I want to create a pulse train generator in DAQmx. I tried many things but the code still doesn't work.
I wish to use CTR0OUT (alias GPCTR0) as pulse train output.
Can anybody help me with a little sample code?
(I'm using PCI-6023E.)
Thanks!
- George Cs.
(5,128 Views)
Dear George
I'm assuming you're trying to implement the pulse train generator in an NI
development environment ...
In LabVIEW consider the example 'C:\Programme\National Instruments\LabVIEW
8.2\examples\DAQmx\Counter\Generate Pulse.llb\Gen Dig Pulse
Train-Continuous.vi'.
In CVI you should get started looking at 'C:\Programme\National
Instruments\CVI81\samples\DAQmx\Counter\Generate Pulse\Dig Pulse
Train-Cont\DigPulseTrain-Cont.prj'.
Best regards
Philipp R.
(5,119 Views)
Dear Philipp!
>I'm assuming you're trying to implement the pulse train generator in an NI development environment ...
No. I'm using DAQmx API functions only. I surveyed the Ansi C examples, but there is no CTR0OUT example.
I tried the following functions with many combinations, without any success:
DAQmxCreateTask("", &TaskGPCTR);
DAQmxCreateCOPulseChanFreq(TaskGPCTR, "Dev1/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, 10.00, 0.50);
DAQmxCreateCOPulseChanFreq(TaskGPCTR, "Dev1/Ctr0Out", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, 10.00, 0.50);
DAQmxCreateCOPulseChanTicks(TaskGPCTR, "Dev1/ctr0", "", "/Dev1/Ctr0Out", DAQmx_Val_Low, 0, 10, 10);
DAQmxCfgDigEdgeStartTrig(TaskGPCTR, "/Dev1/Ctr0Out", DAQmx_Val_Rising);
DAQmxCfgImplicitTiming(TaskGPCTR, DAQmx_Val_ContSamps, 1000);
DAQmxExportSignal(TaskGPCTR, DAQmx_Val_CounterOutputEvent, "/Dev1/Ctr0InternalOutput");
DAQmxStartTask(TaskGPCTR);
So I need a tiny code snippet for this task!
Thanks!
- George
Message Edited by George Cs on 09-05-2007 06:12 AM
(5,117 Views)
Dear George
The simplest piece of code that proved to work for me was:
#include <NIDAQmx.h>
static TaskHandle gTaskHandle = 0;
DAQmxCreateTask ("", &gTaskHandle);
DAQmxCreateCOPulseChanFreq (gTaskHandle, "Dev1/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, 1.0, 0.5);
DAQmxCfgImplicitTiming (gTaskHandle, DAQmx_Val_ContSamps, 1000);
DAQmxStartTask (gTaskHandle);
What exactly happens if you run that?
Best regards
Philipp R.
(5,109 Views)
I don't believe it!...
I just realized that I'm continually trying to acquire the generated square wave on "Dev1/ai0" while CTR0OUT pin is connected to ACH1 ("Dev1/ai1")!... 8-/
Of course your sample is working. (I started with the same code one day ago...)
Mea culpa...
Thank you for the tip!
Best regards
- George
Message Edited by George Cs on 09-05-2007 09:03 AM
(5,107 Views)
Do you see pulses on CTR0OUT?
I'm trying to do the same thing.  I thought I would see the pulses on CTR0OUT but I don't.
-CBJohnson
(4,732 Views)
Hi CBJohnson,
Yes, of course I see the pulses, though my code is a little bit different, because I wrote it in Delphi pascal and I used another pulse frequency, but this sample code is ok.
Greets
- George Cs -
(4,721 Views)
