Counter/Timer
Pulse frequency Vortex meter
Hi everyone,
I am trying to read the output (4-20mA pulse) of a vortex meter system to regulate an air flow rate.
The old system is using a display 415A.10E from contrec and the reading is working fine.
I am trying to read this same pulse signal with NI modules but I am stuck, after trying different solution none gave me a stable signal.
I have two module I tried to use, NI-9361 and NI-9401.
Since it is my first time trying to read a pulse signal via labview I turn to you for pointers !
Can someone help me? How to configure the Daqmx routine? is there some special conversion needed?
Thanks for your help
Yann
Message 1 of 1
(3,234 Views)
