Counter/Timer
Pre Buffered and time critical DAQ
Dear reader,
I want to create a timing system concerning this I have a question. Is it possible to write data that should be given out by a DAQ card in to the buffer of the DAQ card and to programm the buffer like that, that the DAQ card gives out the signals when a certain event occurs. The event shall be a hardware triger generated by an FPGA card transmitted via the start trigger port (wich comes from the start trigger slot) of a PXI (PXI 1042) system.
Somebody told me that this is possible in generall. But the timing system is time critical (in the dimenson of ns), that is why I want to write the data in to a pre Buffer of the DAQ card. Is there a pre buffer at all? ( I didnt find information's about that on the data sheeds of the daq cards). Or is the data always written in to such a buffer? What is all in all the limit for Analog output? Is it the update rate which is written in the data sheeds of the DAQ cards (for example 2,86 Ms/s for NI PXI 6259) or is it possible to make faster output? What about digital output? The NI PXI 6259 for example has an max source frequency for the timer/counter of 80MHZ. Can i perform digital output with that freuquency?
Also I would like to know which is the fastest DAQ card (Analog and digital output) available?
Thanks a lot for the support.....best regards...Sebastian
(4,255 Views)
(4,032 Views)
