Counter/Timer
Position from two signals Encoder A and B using counters in a session based DAQ
Hi all,
I'm having some trouble getting the position of one tool. This is because the position should be computed from two quadrature signals (encoder A and encoder B), which I wanted to acquire with a NI cDAQ-9178 chassis and a NI 9402 module under Matlab 2012a (7.14, drivers are DAQmx-9.5.1).
The problem is that during the acquisition the second counter 'ctr1' of my session is 0 at anytime while the real signal is correct (I've checked with an oscilloscope).
Here is my code :
function MultipleCounterTest
% Getting updated hardware informations d.Chassis = daq.getVendors;
% Creating measurement session 1 s = daq.createSession(d.Chassis.ID);
% Adding channels to the measurement modules s.addAnalogInputChannel('cDAQ1Mod2','ai2','Voltage'); s.addCounterInputChannel('cDAQ1Mod4','ctr0','EdgeCount'); s.addCounterInputChannel('cDAQ1Mod4','ctr1','EdgeCount'); s.DurationInSeconds = 1; s.Rate = 1*1E2;
l = s.addlistener('DataAvailable',@f);
 function f(src,event) hold on; figure(1); A = event.Data(:,2); h = plot(event.TimeStamps,A); set(h,'Visible','On'); set(gca,'Visible','On'); set(gca,'XLim',[0,s.DurationInSeconds]); set(gca,'YLim',[-max(A)/5,max(A)*6/5]); set(h,'LineStyle','-'); set(h,'LineWidth',1); set(h,'Color','Green'); set(h,'Marker','o'); set(h,'MarkerSize',1.5); set(h,'MarkerEdgeColor','Green'); set(h,'MarkerFaceColor',[1,1,1]);
hold on; figure(2); B = event.Data(:,3); h = plot(event.TimeStamps,B); set(h,'Visible','On'); set(gca,'Visible','On'); set(gca,'XLim',[0,s.DurationInSeconds]); set(gca,'YLim',[-max(B)/5,max(B)*6/5]); set(h,'LineStyle','-'); set(h,'LineWidth',1); set(h,'Color','Black'); set(h,'Marker','o'); set(h,'MarkerSize',1.5); set(h,'MarkerEdgeColor','Black'); set(h,'MarkerFaceColor',[1,1,1]); hold off; end
% Executing acquisition s.startBackground(); s.wait();
% Deleting measurement session delete(l); s.stop; s.release; end
Is there any way to get both outputs of two counters ('ctr0' ad 'ctr1') from a same module ('cDAQ1Mod4') working in the same session ('s') in matlab with a session based DAQ?
Thank you very much, your help would be much appriciated...
Csaba
(6,931 Views)
Try to have a look in MAX to see whether the module is working properly!
(6,915 Views)
