Counter/Timer
Photon Counting, Time Stamping, and basic help with how DAQmx works
thanks for the examples. I got the time stamping working with a pulse train generator and can acquire frequencies as high as 2 MHz (still not really high though...)
The problem is that when I connect a real photon detector (SPAD with TTL signal) shortly after starting acquisition I get the error that some data was overwritten since the data could not me read out as fast as necessary. The actual count rate of the SPAD is only a few thousand counts.
error message:
Error -200141 occurred at DAQmx Read (Counter 1D DBL 1Chan NSamp).vi:1
Possible reason(s):
Data was overwritten before it could be read by the system.
If Data Transfer Mechanism is Interrupts, try using DMA. Otherwise, divide the input signal before taking the measurement.
Task Name: _unnamedTask<99>
would appreciate any help with this
steffen
Message 51 of 51
(1,401 Views)
