Counter/Timer
PXI6602: Setting up for simple data capture
I am attempting to setup a simple input capture with a PXI 6602 card in LabWindows. I have 8 signals which I would like to read back at a rate of 100Hz into an array.
When I attempt to set the sample clock DAQmx throws error -200077, with the following description:
"Function DAQmxCfgSampTiming:
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: DAQmx_SampTimingType
Requested Value: DAQmx_Val_SampClk
You Can Select: DAQmx_Val_OnDemand"
I am using this card for another task which does on demand reads of the current state. Am I missing a step to reconfigure the card for clock sampled input? My current code sans error checking is this:
    DAQmxStopTask(TIO_read); //On demand task
    DAQmxCreateTask("Sample Clock",&TIO_clock);
    DAQmxCreateCOPulseChanFreq(TIO_clock,"TimingIO0/ctr0","100Hz_clk",DAQmx_Val_Hz,DAQmx_Val_Low,0,100,0.5);
    DAQmxStartTask(TIO_clock);
    DAQmxConnectTerms("/TimingIO0/ctr0InternalOutput","/TimingIO0/PFI36",DAQmx_Val_DoNotInvertPolarity);
    DAQmxCreateTask("Startup Timing",&TIO_samp);
    DAQmxCreateDIChan(TIO_samp,TI_PORT"/line7:0","",DAQmx_Val_ChanPerLine);
    DAQmxCfgSampClkTiming(TIO_samp,"/TimingIO0/PFI36",100,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000);
    DAQmxStartTask(TIO_samp);
Any ideas?
(5,854 Views)
What is your NI DAQmx version?
What is your Labview version?
(5,834 Views)
