Counter/Timer
PXI 6602 - Retriggerable Finite Pulse Train Generation
I have a VI in LV7.1 where I configure PXI 6602 to generate finite pulses whenever a trigger is received. And the Retriggerable Property is set to TRUE. I look for the task to complete in order to proceed with the other operations.. This actually works. As soon as the pulses are generated DAQmx Task Done becomes TRUE.
The same VI I upgraded to LV 2011but this time the 'DAQmx Task Done?' never becomes TRUE even after the trigger is received and pulses are generated.
Does anyone know if the 'DAQmx Task Done?' functionality is changed in higher version of LabVIEW so that it no more works as it was in LV 7.1?
Is yes, then do you know what property to use to know that the operation is done?
Any help is highly appreciated.
Thanks.
Message 1 of 1
(5,527 Views)
