I am using a PXI 6602 with BNC-2121 Connector Accessory and LabView 7.1 to measure a time in a cams programmer (it is composed by a motor, cams, microswitches. The cams rotate and commutate the microswitch state). I need to use all eight counter but for the moment I set up the program with only one counter ( only one cam). When the measure start I need to count the seconds until the microswitch commutate. In a complete rotation of the cam the microswitch can commutate more times and I need to measure every operation (see Figure 1) and I want to save every time (ti) in a matrix because in a second time I would create a output plot. There is a difficult in this measure: when the microswitch commutate there are a rebound problem. The rebound time (Tr in Figure 2) in negligible respect the cams programmer tolerance and I want eliminate it from my measure. Can Somebody help me to write the program, I am new in LabView world.
Thank you
Luca
