Counter/Timer
PFI output for internal counter
If a PFI pin on a 6259 is set to be an output, can the output signal also be routed internally to one of the counters?  Or do I have to take the output signal and physically wire it to a second PFI pin that has been configured as an input?
Message Edited by pml2106 on 10-14-2005 01:04 PM
(4,332 Views)
Hello pml2106,
Depending on what resources of your device are already in use, you might be able to do that, assuming you are talking about a digital output on your PFI line.  Use the "DAQmx Connect Terminals.VI" in LabVIEW, or DAQmxConnectTerms function if using the C API.
-Alan A.
(4,313 Views)
I'm using Labview 7.0 where would I be able to find "DAQmx Connect Terminals.VI"  I can't seem to find it anywhere.  Another source says that its in the function palette under DAQmx, but I can't seem to find that function on my function palette.  Is it because of the version of labview that I have or is it because I'm looking in the wrong area?
J
(4,171 Views)
In LabVIEW 7.0, the DAQmx Connect Terminals.vi is here:  All Functions>>NI Measurements>>DAQmx - Data Acquisition>>DAQmx Advanced>>DAQmx Signal Routing palette.  If you don't have it there, you probably don't have a recent enough version of NI-DAQmx, which you can download here.
-Alan A.
(4,163 Views)
