Counter/Timer
PCI 6602 counter Application
Hello ,
I want to write a code which generated PWM on counter 0 and measures 3 PWM signals on counter 1, counter 2, counter 3 .
I know how to generate a PWM ... i am still trying to figure how to measure it thou.
when i want to measure the PWM should i provide my signal to the source ( PWM ) and gnd. Is that the hardware set-up.
Moreover it is possible to do in real time ....( generation and measurment simultaneously).
Please help !!!
Thanks in advance.
Sweety Agarwal
(5,358 Views)
It is possible to do what you say and measure and generate simultaneously.  To measure a PWM, you need to set up a counter input task for semi period measurements with implicit timing.  Then wire your signal into the gate.
-Christina
(5,251 Views)
