Counter/Timer
PCI-6281 How to use80 mHZ timebase for A/d and D/A sample clocks
Does anyone know how to use the 80 mHZ internal clock as the timebase for my A/D and D/A sample clocks rather than the default 20 mHZ timebase?
I am using straight NI-DAQmx version 8.3 with C code. No Lab View, no Measurement Studio.
I have an application which uses the D/A to generate a sequence that is collected by the A/D.  The D/A is clocked out at an integral multiple of the A/D clock.  In order to maintain this integral relationship I can only use a limited set of Sample Clock Timebase Divisor pairs (as returned by DAQmxGetSampClkTimebaseDiv).  This means that am further from my desired base frequency than normal.  For example, using the degault 20 mHZ timebase, if I want a 2000 hz center fequency, the closest I can get is 2003.205 hz.
I cannot find anyway to use the 80 mHZ internal clock as the timebase for my A/D and D/A sample clocks.  If I could, it would be possible to get closer to my desired center frequency.
(3,374 Views)
Post is responded to in the multifunction DAQ forumn.
Have a good one.
Michael D
Applications Engineering
(3,361 Views)
