Counter/Timer
PCI 6220 digital I/O CB68LPR
I would like to know how to connect the PCI 6220 with CB68LPR for digital input and output? appreciate your answers.
regards,
nazreen
(4,515 Views)
Hello Nazreen,
You can use the SHC68-68-EPM 68 Pin Shielded Cable (part #: 192061-01) to connect your PCI 6220 to the CB-68LPR.  The CB-68LPR connector block has 68 pins labelled "J0" through "J67".  These pins have a one-to-one correspondance with the 68 pins of your PCI 6220, i.e. pin "J5" of the CB-68LPR correspondes to pin 5 of the PCI 6220.  From looking at the M-Series Help manual under 'IO Connectors and Pinouts'', you can find what pins correspond to what actual signals on your DAQ device.  The PCI 6220 has three ports (groups of 8 lines) available for digital I/O.  I can see from the pinout diagram for the 6220, that port 0 line 0 (P0.0) corresponds to pin 52, or terminal "J52" on the CB-68LPR.  I hope this helps!
Travis G.
Applications Engineering
Message Edited by Travis G. on 04-05-2006 04:54 PM
(4,501 Views)
