Counter/Timer
Output same TTL as input
Like to know if the same TTL signal that is being measured (then manipulated) as input can also be output to another instrument.  Using a cDAQ and a 9401.
(3,602 Views)
Hello Aaron,
The NI 9401 has 8 bi-directional digital IO lines.  It is possible to read in a TTL signal, manipulate it, and then output it on another line, however there is inherently a delay because you have to read, manipulate and output sequentially.  One programming technique that can be used to speed up this response time with a multicore computer is called pipelining.  For more information on this please see this article:  Programming Strategies for Multicore Processing: Pipelining.
The primary limiting factor is the rate at which you can run your loop.  This is limited by several things including the computation time, but on a windows operating system you'll top out somewhere on the order of 1 kHz.  This will vary considerably on different computers so your results may be better or worse by a factor of 2 or more.  If you require the feedback to be much faster then you may need to consider changing to a real-time operating system or FPGA programming/hardware.
I hope this helps and have a great day!
Brooks
(3,586 Views)
