Counter/Timer
No proper signal with NI-4351 DAQ-card
I am trying to use a NI-4351 for temperature  measurement (together with TX-68T connector block). However, I don't get a proper signal in our laboratory. Using the MaX  and looking at  the test panel: there is sometimes the right voltage but most of the time  the signal is noisy or even more than that: it is jumping to the maximum and minimum of the voltage range (for every voltage range).
In an another building with another supply circuit the signal is okay. So we suppose an EMC problem: Together with the Elec. department we have disconnected all "critical" consumers- no change, also filtering the supply of the PC has no effect.
Can you propose a special supply voltage filter? The noise frequency is very low (less than 1 Hz). Other lab cards and electronic devices work properly under the same conditions. Has anyone ever had this kind of problem? Any solutions?
Thank you.
Bernhard
(3,148 Views)
double post
refer to http://forums.ni.com/ni/board/message?board.id=250&message.id=13633
Message Edited by TimoS on 07-06-2005 03:46 AM
(3,130 Views)
