Counter/Timer
Max. rate for sample clock source
thinking of a future application for digital event counting (similar to the Count Digital Events-Buffered-Continuous-Ext Clk example ) we have two questions:
What's the maximum rate applicable to the sample clock  source terminal  (in our case the external signal has rates up to 500kHz)?
Why needs the sample clock rate to be specified as the signals at the source terminal determine when a sample is written to the buffer?
Thanks a lot for any answer!
(3,556 Views)
Hi Werner
For rates about 500kHz it must be work and you need the sample clock rate because you can also choose other rates to read the buffer.
regards
Manuel
(3,537 Views)
