Counter/Timer
Looks like the Serial Number Property Node is broken for PXI-6651,52,53 but it is good for a PXI-6682.
I want to retrieve the serial number for some Timing and Sychronization PXI cards.
Specifically the PXI-6651, PXI-6652, PXI-6653, PXI-6682.
I have tried using both DAQmx and niSync Property nodes on these cards.
The property nodes works for the PXI-6682 but not the other three cards.
I am using LV 8.5.1 on a desktop with MXI exrpess cards connected to PXI-1045 chassis which house the T&S cards.
Anybody have any ideas?
McKevin.
(4,052 Views)
Hi McKevin,
I looked at the attached code and the NI-Sync property node will not return a serial number from the device without initializing a sync session first.  I have modified the code and reattached it below. It was tested with NI-Sync 3.0 and the PXI-6653/6652.
Andy L.
(4,007 Views)
Hello McAndy,
I put in the the niSync Initialize before the Property Node,
but I still get FFFF as the serial number for the PXI-6651,52,53.
PXI-6682 report the same SN as MAX.
McKevin
(3,992 Views)
