Counter/Timer
Inverted signal from CB-68LPR
I hope to get some tips on my instrument.
I've been using CB-68LPR connector block and 6602 timer/counter.
The problem is that one of the output pulse from CB-68LPR has to be inverted.
I've been thinking about connecting an inverter on it but it seems overkill.
Thank you,
(5,827 Views)
Inverting the signal can be done in software, if you are using LabVIEW then you can use the invert function to invert the data, you may need to convert the data to boolean invert it then convert back to the orignal data type. Let me know if this is helpful.
Justin Petry
Justin
Product Support Engineer - Conditioned Measurements
(5,795 Views)
