Counter/Timer
Input counting
Hi lads.
i'm new at labview. and i'm wondering how to make a program counting pulses in labview.
This is the case:
I got a movment sensor placed at my door. And i wanna see on labview how manny has enterd the room. So every time the input is high i want labview to count 1. and if it gets high again, then is 2 and so on.
And ofc a reset button.
Would be awsome if someone can help me.
Best regards
Henrik
(6,797 Views)
Hi Henrik,
What are you using to digitize the output of your sensor and what kind of values does the sensor output?
I've used a VI similar to the one attached below to do this in software given a single-point analog input signal.  It arms an event counter when the input signal is below a certain threshold, and increments a counter when the signal raises above a different threshold.
Best Regards,
John Passiak
(6,791 Views)
Hi John
My sensor is pointed against a reflector. So everytime someone walks into the room the reflection is broken. then the sensor Sends out a 24V signal.
So when my input is high, i want my labview program to count 1 up. if you get me?
Thank you for helping
(6,765 Views)
Hi Henrik,
Do you have a DAQ card to convert the 24V signal into something that can be read by the computer?
Best Regards,
John Passiak
(6,754 Views)
