Counter/Timer
In Delayed Pulse Generation vi,Problem With THE PULSE WIDTH??
In Delayed Pulse Generation vi, I want to input a very low number for the Pulse Width while using an external timebase source. But the minimum pulse width has to be 2. Does anyone know how can I solve this problem??
(3,344 Views)
Hey 45,
Unfortunately, there is no way to generate a pulse width smaller than 2x your external timebase.
There is an option to create a pulse of arbitrary width of your external source if you can afford some software processing in between. What you can do is use 1 counter to measure how many source edges of your card's internal timebase (80 MHz for TIO only, 20MHz or 100kHz for TIO and STC) your external signal is. This uses pulse width measurement as the counter application. Once you know how many source edges it takes to represent your pulse, then you can use triggered pulse generation and use the internal timebase with the pulse specs set to create the exact pulse width you want (and delay) and you can use your external pulse as the trigger. Th
is works well if your pulse is always the same width and you can measure it before hand. As an example, let's say your pulse is 20 internal timebase pulses when measured. This means you can use the pulse specs to specify a pulse width of 0.75 your pulse width by using only 15 internal timebase edges for your pulse width.
I don't know if I was clear above or not but if you give me your exact application you are looking to achieve, I might be able to help you out. Hope that helps.
Ron
(3,344 Views)
