Counter/Timer
How to trigger automatic input data changes
hi I am very new to labview, as a part of an experiment i need to control an agilent N6700B mainframe voltage controller using labview. I had established all the comm using GPIB . At the moment I am able to control the output voltage by using the attached labview program (this is a modified version of the example program i got from agilent). Whenever i give a voltage input in labview (marked as red in block diagram) I am getting the same voltage at hardware output.
Following are my questions
1) how I can change this manual voltage entry to an automatic mode . For example when i click run output should change to 5 V then without pressing anything it should change to 15 V after some seconds,later change to another Voltage.
2) when I press stop ,labview is stop working.but the hardware is stillgiving an output voltage, how can i reset my hardware (change voltage to zero) by pressing stop button
3) this program iscontrolling only one channel of my hardware. my hardware has multiple channel outputs. How I can controll all simoultaneaosly . I tries to copy and paste the block s to create another branch. But allchannels not working when I did so.
My quistions might be silly as I am really new in labview. But it will be really helpful if you can give a hand
Message 1 of 8
(7,083 Views)
Ok, time to step away from the example.
You need to initialize your connection ONCE.  Do no do that inside of the loop.  Same for closing the connection.
There should be an input to those VIs for which module you are talking to (the N6700 can hold 4 modules).
If you step away from the example some and think about what you need to do and when, it will become obvious what you need to do.  Think about how you would do it manually.  Then think about each step you took and concider what code you have to do that step.
Message 2 of 8
(7,065 Views)
Thank you crossrulz for the reply.
I didn't really get some of your inputs.
# what is do no do inside the loop ?
# can I use a timer or counter for making it automatic ?
Kindly help
Message 3 of 8
(7,058 Views)
Unless you are trying to externally trigger the instrument with an NI DAQ card, I don't know why you posted here.
You really need to take one of the free tutorials or classes. Understand that it is s waste to repeatedly initialize and close the instrument and the only thing that should be inside a loop is your set voltage function. For example, put it inside a for loop and pass in an array of voltage values. A simple wait would control the duration. Once you have it working for s single channel, you would add an array of channel names and perhaps nest a couple of for loops.
Message 4 of 8
(7,045 Views)
Hi
Message 5 of 8
(7,032 Views)
Hi
Message 6 of 8
(7,030 Views)
The best thing would have been to click on Options and request the moderator to move the post.
Message 7 of 8
(7,020 Views)
Hi Dennis_Knutson
i had requested the moderator to remove my post. Sorry again
Message 8 of 8
(7,013 Views)
