Counter/Timer
How to route a channel (from SCXI-1125) to counter input (via PFI on PCI-6036E)
(3,268 Views)
The SCXI channels are connected to the analog input stage of the E-series board. You cannot internally route an AI channel to a counter pin - that is why this has to be done externally with wires. The problem is, that you have your SCXI chassis connected to the 68 pin connector of the board. To access the counter- , analog output- and remaining digital channels you would need to use a so called feedthrough panel; the SCXI 1180.
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,259 Views)
