Counter/Timer
How to convert cluster to array
How to convert cluster of 2 element to 2D array???
(9,938 Views)
This operation will only work if the data types of the elements in the cluster are identically the same. You may unbundle the cluster elements, and subsequently use the build array function.
Again, clusters and arrays are fundamentally different. Should an array be used throughout the application without this conversion?
Cheers!
Patrick Corcoran
Application Engineering Specialist | Control
(9,922 Views)
How can I convert the result of vision builder (auto code generated) in labview and display it in a report.How to convert the 5 element cluster to a table or array.
(9,417 Views)
Philipson,
Within LV there is a function called "Cluster to Array Function". There also exists a function called "Array to Cluster Function."
Hope this helps!
Robert B
RF Product Support Engineer
(9,403 Views)
