Counter/Timer
How do I use AO update in the Route signal.vi
Hi support,
My goal is to create a waveform (to buffer it) and output it using the analog card (PCI-6713) N times and with the frequency F. Apperanlty this is done using a (actually 2) digital counter(s) on the PCI-6602 card.
This is done using route signal.vi using "AO update". However I have not managed to get it working. I only get error -10341. So my questions are how do I do it? More specificly how do I use AO update in the Route singal.vi Do I need to conect the cards in any perticular way (cabels or so)? Also do you have more information about how the vi route signal works (the help file does not help me much)?
Grateful for all help.
I'm using labview 6.0 as developpement platform, and using the PCI-6601, PCI-67
13 and a PCI-7344 cards. Since the program is quite large I will only send a portion of it, the pulseGen is supposed to generate the waveform (loaded as a text file, also submitted) the digital output used is in case 1 (in pulseGen) the analog output is in case 3. The MissingWaveform.vi is just to ensure that a waveform is supplied to the pulseGen.vi
Sorry about the mess.
/Chatri
(3,328 Views)
Cabling and Interfacing between Boards: You have capability for direct simultaneous connection between 6713 and 6602 (also 6601) via the RTSI bus, but you need to get a cable to connect between the boards. You can connect between the boards using the I/O pins of their respective signal conditioning hardware. These connections are slower. There are also PFI (Programmable Function Interfaces) connections that are set within the VI's.
All that said, it is not obvious why you want to use the RTSI. You can use the PCI-6713 to generate AO. Presumably you have some signal conditioning accessory; which ever pin of that accessory the AO appears on, you wire it over to the SC accessory for the 6601 and the appropriate pin for the counter gate or
source you want to use.
Suggestions: Don't try to work in the context of your big VI for now. Get the AO bit and the counting bit to work together by themselves. Then shoe-horn them into the big VI. Also, consider a call to the NI help line. They are very good. 800.433.3488 (800IEEE488)
In case you hadn't noticed the DAQ cards and Counter/Timer cards come in different flavors and there are specific example VI's to suit. 6602 uses NI-TIO chip, but PCI-671X are DAQ-STC. Again the NI help people are good at catching this kind of stuff.
Your question is rather large and hard to manage. Perhaps if you break it down into small chunks the advise will be more free flowing.
mike
(3,328 Views)
