Counter/Timer
How do I change pulse specs on retriggerable pulse generation
I am trying to dynamically control the delay and pulse width of a retriggerable pulse on a 6602. I have used info from "Generate retriggerable pulse switch cycle.vi" and PWM examples and discussion forum subject "Deterministic updating of retriggerable pulses". If I use the switch cycle, it doesn't work at all. If I just use "program", it works but sometimes my pulse is shortened or missing (I assume this is when the pulse specs are re-written). How can I asynchronously change pulse specs without interrupting the current pulse?
(3,342 Views)
This is not possible with the current hardware. You can change the pulse specs only if you halt the operation.
RamziH.
(3,342 Views)
