Counter/Timer
How can I output a series of voltages using a low-frequency external trigger
Hi all,
    I tried to output violtages triggered by an external TTL with a very low frequency (below 1 Hz).The voltage serises is a real-time made 1-D array or read from a predefined ASCII file. I want it do it that the analog output will change to the next voltage in the array when a rising edge of the trigger source comes .But I always get the error message "DAC conversion attempted before data to be converted was available" when I try to run it.
    Is it because the trigger frequency too low? Can anybody help me?Thanks.
(3,544 Views)
Type:USB6211
(3,539 Views)
