Counter/Timer
How To Creat Sequential Timer.vi
         iam devlope the progarm in labVIEW-8.2 with PLC to connected via  MODBUS
 Communication. i want to create Sequential timer Cease structer.vi, i try some
 methode but that meathode not work properly because the timers not reset, so
the program not work next cycle. i required execute one by one timer but onethink
the timer value set user defind.
Thankyou
   Krish
(6,349 Views)
Krish,
Can you tell/show me what methods you have tried? I am not familiar with the VI you are referring to. Could you please explain what you are trying to do further and post a screenshot of your code?
-Marshall R
(6,321 Views)
Hi Marshall,
       I Attached the Sorce code of Sequential Timer vi.
 i required execute one by one timer but onethinkthe timer value set user defind, and
execute only one steucter at the same time.
Thankyou
krish
(6,263 Views)
I would try the "Wait" found under Programing»Timing. Or you could also try wiring the "Auto Reset" terminal on the Elapsed Time.vi that you are currently using, so that the timer will reset every time.
-Marshall R
(6,239 Views)
     Elapsed timer reseted ok. but i want execute only one cease structer at the time.
  ie; my sequential timer.vi was reset properly, if run the second waveform but
intrupted the another waveform, that's my problam.
(6,231 Views)
If I am understanding your question properly, it is changing between cases between you are using nested case structures.  If you only want one or the other to execute, you will need to put them in different cases, instead of nesting them.
Lauren
Applications Engineering
(6,174 Views)
