Counter/Timer
Hardware connection between NI 9215 and 9361
Hello to all,
Please I have one question maybe it would appear a little bit "weird".
This my first real project with NI DaQmx.
I need to acquire voltage measurements Through NI 9215 (BNC), and using The NI 9361 counter, I should measure the frequency and the period of these measurements according the counting edge.
Here my first question is the hardware connection and the communication between the  NI 9215 and 9361, how can I wire the channels. I thought that through the NI MAX I can really manage that... but I seems to be not feasible..
Sorry, maybe this is trivial for most of you... but I am really stocked at this point.
Hope that someone could help..
Many thanks in advance..
Greetings...
Youkou..
(2,780 Views)
Hello youkou,
the 9215 is for the analog measurement, what you can do, is a post processing of the analog signals to get the information you want. There is no direct connection between the moduls, if the analog signal is in range (voltage, shape) of the 9361 then the signal can also wired to the 9361 in parallel, so you can use the internal counter of the board for the measurement.
best regards
Alexander
(2,748 Views)
