Counter/Timer
Hardware Timed dual counter output with changing delay on second pulse
I am using a USB-6351 to control a piece of external scientific equipment. What I need from this device is the ability to generate two pulses. The first will be a consistent pulse triggered by an external TTL pulse (Counter 1 in the image attached). This should be retriggerable, but only sending a single pulse per input trigger. I have this portion functional at this time. The second counter needs to trigger from the first counter and have its own high time (low time is the same). What needs to change is the initial delay on this second counter. My software should sweep through the initial delay from a starting value to an ending value with a specific (user supplied) step. Ideally, I would like a for loop that allows multiple pulses at each delay before moving to the next delay. What I have tried so far is to start the second counter, wait for it to complete, stop it, and then use a property node to change the initial delay. This worked, but missed about 1/2 of the triggering pulses, no matter the external timing (approximately 2 Hz when I'm pulsing at around 50 Hz when triggered; 0.2 ms pulse outputs). The code shown below is a snippet that is incomplete. This functions to produce a second, retriggerable pulse with the correct initial delay. I need help getting it to change with each pulse. Thank you in advance!
(679 Views)
We can't debug an image. Please upload your code instead, preferably in LabVIEW 2019 as most community users don't have access to the latest LabVIEW version.
https://tmesystems.net/
(666 Views)
My Apologies; I've seen images uploaded previously and thought that was sufficient. Attached is the snippet of code that is not functioning as expected. Thank you!
(639 Views)
Replying to bump to the top; is what I am trying to do here (please see first post and 2nd reply with a *.vi file attached) possible in LabView?
(598 Views)
Finally got around to looking at this in more detail.   I don't have hw available to test, so here are some speculative thoughts.
I don't think you're using the AutoIncrCnt property right.  It wants to set up its own schedule of auto-increments, but you keep re-feeding the task with a succession of externally-incremented values.  You shouldn't be doing both.
However, one big caveat is that I simply am unsure whether that property retains its auto-inc schedule through retriggering.  I've only ever used it in a finite sampling task that didn't involve retriggering.  It behaved as expected in my case, each successive idle time was longer than the one before by the # of timebase ticks specified by the AutoIncrCnt property.
My educated guess is that it won't work the way you'd like through retriggerings.  It'll probably remember the AutoIncrCnt value itself through the retriggerings, but it'll probably keep resetting the starting point to be the original idle time or initial delay value.
I could easily be wrong though so it's worth a try.  Beyond that, I don't think I have any alternative idea for an exact solution with conventional LabVIEW and DAQ device.  It seems like an FPGA approach would be needed.
-Kevin P
(517 Views)
