Counter/Timer
Getting an angle!!
PCI-6221 (68-pin)
I've been struggling to make my measurements into something i actually can use.
I have attached an encoder inputs to the CB-68LP as following:
Ch A, pin 37 (PFI 😎
Ch B, pin 45 (PFI 10)
DGND, pin 7
+5V, pin 14
Check the attached file for labview-implementation.
The setup is pretty much the same as in "Measure Angular Position.vi"
So, whats my problem?
I dont understand what im measuring. I know it should be an angle that goes from 0 degrees up to 35 degrees, but i cant make labview to understand this. The value in LabView goes from 0 to 1500 with unit degrees.
The encoder is a 12-track encoder, according to specs one count corresponds to  45/512 degrees.
/jacob
Message 1 of 1
(3,563 Views)
