Counter/Timer
Gen Digital Pulse Train Finite Retriggerable - Initial Delay is only for first trigger
Hello Aman,
If you place down the DAQmx Timing VI on a block diagram, right click on it and select help you will get a list of all the inputs (i.e. rate, source, samples per channel, etc) and a description for each.  For example the samples per channel input says "samples per channel specifies the number of samples to acquire or generate for each channel in the task if sample mode is Finite Samples. If sample mode is Continuous Samples, NI-DAQmx uses this value to determine the buffer size."
I am not familiar with the example you are mentioning, however if you look at the DAQmx shipping example located in NI Example Finder under Hardware Input and Output >> Digital Generation you will find an example called Cont Write Dig Port-Ext Clk.vi.  This example shows you everything you need to configure with the digital output.
In this shipping example you need to specify the clock source and the rate.  They are both inputs to the DAQmx Timing VI.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
Message 31 of 32
(1,666 Views)
X Series Supports it Smiley Happy
with DAQmx >= 9.0 you can use the Channel Property Counter Output:General Properties:More:Enable Initial Delay on Retrigger Property
-gaving
Message 32 of 32
(1,300 Views)
