Counter/Timer
GPS with PXI-6608 and RealTime OS
Here are the facts:
My goal is to decode a GPS Time from a GPS card but here are the facts:
I am running a PXI-1000B chassis using LabVIEW Real Time OS. I have a PXI-6608 Timing Module in Slot 2 and a Symmetricom bc637C PCI GPS card in slot 6. I wire the DC Level IRIG-B signal from the GPS card to the PXI-6608 into pin 15 (PFI7) on a terminal block. I wire the ground to pin 14.
Then I run the "Measure GPS Timestamp.vi" with the LabVIEW target as the PXI chassis. The settings for this VI are
      GPS Counter = Dev1/gpsTimestampCtr0
      GPS Synchronization Method = IRIG-B
      Synchronization Source = PFI7
I do not get valid information and even if I remove the terminal block from the 6608 card, the result (seconds) is not influenced. It appears that the GPS signal is not being seen.
Any suggestions?
Thanks.
Michael Froehlich
(3,642 Views)
It sounds like you have things connected correctly.  The PCI card you mentioned outputs an IRIG-B signal, which is what the 6608 needs.  However, there are several standards of IRIG-B -- the PXI-6608 will accept TTL standards B000, B001, B002, and B003 only. You may want to double check you GPS receiver to make sure it is outputting its IRIG-B signal as a DC level.  It may be possible for you to select what IRIG-B standard to use as output on your GPS device.
You could check what type of signal you are getting from your GPS receiver with an O-Scope or a multifunction DAQ board. It should be a DC level TTL signal. See the following KB.
You may also want to do simple validation of your PXI-6608 by simply connecting a TTL level switch or signal to PFI7 to make sure that pin is working on your device.
Doug M
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(3,638 Views)
