06-05-2008 10:37 AM
06-06-2008 12:41 PM
I can explain why you get those anomalies as sequential pairs -- the counter is seeing an extra edge in the midst of one of your true frequency intervals. You can check this by comparing 1/138,9 to (1/254,1 + 1/306,3). The extra false edge divides one true freq interval into 2 chunks.
It's pretty notable that such a glitch keeps occurring at the same point within your freq interval. It sounds very likely to be something systemic. The best solution will be to prevent the glitch from occurring, if possible. If not, and especially if the glitches keep showing up near the middle of your true interval, it's pretty easy to detect and correct them.
Most of your samples will probably agree to within a few % of one another, right? Any time an interval gets split by a glitch, at least one of the intervals will have a freq that is >= 2x the nominal value. In your observations, you get 2 readings that both deviate by >50% of nominal. These can be easily detected in software, and you can recreate the true interval according to the reciprocal formula I showed at the top of this post.
I think I posted on a similar topic before, let me see, yeah... here it is.
-Kevin P.
06-07-2008 05:35 AM
06-11-2008 06:20 AM
06-12-2008 04:30 AM
