Counter/Timer
External trigger to stop counter output on USB 6251.
I am using a USB-6251 to control a small motor using PWM on counter 1 of the device. Does anyone know if it is possible to use a signal on one of the digital input lines to stop the counter output. I am currently looking at a limit switch condition in a while loop, and stopping the counter when the switch goes high. Unfortunately with all of the win2K overhead the response is pretty sluggish.
(4,008 Views)
I believe that you can use a pause trigger in your application and monitor the digital line so that when it goes high or low the counter output will pause. A great example of this can be found by going to Help in LabVIEW>> Find Examples>>Hardware Input and Output>>DAQmx>>Generating Digital Pulses>>Gen Dig pulse train-Continuous-Pause trigger.vi. You can also use a case structure and place a stop task inside of the appropriate case. If you do not need to restart the generation you can use a stop trigger which is further explained in this Knowledgebase entry. I hope this helps!
JaceD
Signal Sources Product Support Engineer
(3,998 Views)
