Counter/Timer
Example for Gated event counting using DAQmx in Visual Basic or .Net
Hi I would like to get an example for Gated Event counting which uses DAQmx in VB environment or .Net. I have a application written for traditional DAQ driver, and would like to reproduce the same function of the program with DAQmx.
(3,807 Views)
Hi
Here is an example of the NI website. It is not for specifically Gated Event Counting but maybe you can alter it and get it to fit your requirements.
http://sine.ni.com/devzone/cda/epd/p/id/4819
Kindest Regards
Yatin
(3,784 Views)
Hi Yatin
Thanks for your reply, but the example says about simple event counting, But i would like to get some examples for Gated event counting. Well, in daqmx we can call Gated Event counting as Edge counting using Digital Pause trigger. It will be great if I get any assistance in this,
(3,780 Views)
