Counter/Timer
Encoder Clk and Direction with BNC-2120 and 6251 M Series
I'm trying to measure the angular position using optical encoder connected to LS-7084. I have connected CLK to PFI3 on BNC-2120 and UP/DN to PFI4. I created two tasks using DAQmx. one task to get the direction and the other to get the counts. I have a problem with passing teh information from the first while loop to the count option on the second task. please advice. Thank You
(3,898 Views)
I don't have LV at my network PC and can't open your vi now, but can offer this:
There's a different method to configure your measurement with a single counter task so that the board's hardware accounts for the Direction bit.  To measure a Clock and Dir type of incremental position signal, you actually do *not* configure the counter to measure encoder position.  You configure it to count edges, and then use a DAQmx Channel property node to further specify that the count direction is controlled by the Dir signal found at PFI4.  The right property is probably found several sub-menus deep in the property hierarchy.
It'll definitely be better to let the hardware deal with this for you than to try to manage the complexity of two simultaneous tasks.
-Kevin P.
(3,888 Views)
CSUN,
Kevin is definitely on track. Please see KB 3Q48K1RM for the property node he is talking about. Knowing you have a BNC 2120 is very helpful, but what DAQ card do you have?
David L.
Systems Engineering
(3,880 Views)
