Counter/Timer
DO wave in step-ncreased frequency, possible?
Using cDAQ 9174 + NI 9402 DIO,
To generate DO wave in gap-step-up mode,   Is it possible and how to set that step-increasment?
for example : one pulse-width + step-changing gap time between pulses
(5,914 Views)
Yes, you can do this with a digital output task by writing the correct waveform to the buffer, or with a buffered counter output task using implicit timing (see this example).  I'd suggest using the counter output (less data has to be transferred, higher timing resolution, easier to program).
Best Regards,
John Passiak
(5,904 Views)
"step-ncreased frequency"  shuld be  "step-ncreased duty cycle", or "dynamic duty cycle"
Thanks for you help.
"buffered counter" sounded like a good idea, I'll try how to buffer.
(5,890 Views)
This like Equivalent Time Sampling, but in Equivalent Time Sampling, gate signal is run in a fixed freauency.
for this step-ineased frequency signal, out signal is also itself gate signal,
reference http://www.ni.com/example/30252/en/
(5,868 Views)
