Counter/Timer
DAQmxCreateCOPulseChanTicks continuos Task
Hi ,
when i start the task  DAQmxCreateCOPulseChanTick it is not continuos, it works only one time.
How to set it continuos without starting e stopping the task in a while, because in this solution it needs to much time.
I want to start the task one time continuously .
Thank you in advance for the answer.
There are 10 kinds of people. Those who understand binary notation, and those who do not.
(6,202 Views)
Accepted by topic author blacksocket
Hi blacksocket,
You'll need to call DAQmxCfgImplicitTiming in order to set sampleMode to DAQmx_Val_ContSamps.  In this case sampsPerChanToAcquire is used to determine the buffer size.
Best Regards,
John Passiak
(6,176 Views)
Thank you very much John
(6,162 Views)
