Counter/Timer
DAQ6602 not recognised by Labview
Ihave installed LABView and The DAQ-6602 couter/timer card, the device appears in the MAX, and the testpanel seems to indicate that it is working. However, I can not seem to use DAQmx Assitant to capture data from it. When it come to select chanels it says that I do not have any hardware that supports this measurement. Do I need to regesiter this hardware elsewhere in lab view. I am runing DAQ7 that came with LABView and there where not any newer drivers with the card.
thanks.
(3,258 Views)
Greetings,
The NI 660x counter devices are not yet supported by NI-DAQmx. Thus, the DAQmx Assistant cannot be used with your NI 6602. You will need to use Traditional NI-DAQ. These VIs are located in Functions >> NI Measurements >> Data Acquisition >> Counter >> Advanced Counter. Furthermore, I would suggest that you examine the example programs available in the following location:
Examples >> Hardware Input and Output >> Traditional DAQ >> Counters >> NI-TIO
Good luck with your application.
Spencer S.
(3,258 Views)
