Counter/Timer
Counting pulses and measuring flow rate per second
Hi everyone
I am using a compactField Point (cFP-2220) controller to measure the flow rate. The flow sensor that i have, gives the output in terms of the pulses. I need to count the number of pulses for a particular interval and divide it by a K-factor( constant value) to get the flow rate. If i select the interval to be of a second, i would want to count number of pulses per second and divide it by K-factor to get flow rate ( per second).
How do i count pulses per second and consequently measure flow rate using this count and K-factor.
Any kind of help would be highly appreciated.
Thanks in advance.
(7,117 Views)
Hello, I am having a similar problem where my sensor (flowscan) will give flow rate in GPH and has a constant K factor of 32000 pulses for 16 GPH.
when i  connected the output to a CRO, am able to see the pulse output. The problem is that , this pulse train is not continuous as my flow is very low. I need to count the number of pulses present in 1 second and accumulate this data for 1 minute and average it to show the flow in LPH.
Anybody having an idea, please share it.
thank you.
(3,043 Views)
There are many options depending on your software/hardware.
  • DAQmx offers the block "counter" which can be configured to count input edges (transitions from low to high for example). It is possible to achieve this via a PXI card.
  • With FPGA, you can create your custom VI with a specified timing and characteristics. In this case rudimentary functions like digital I/O are used in combination with labview loops. Here either 1) a cRIO chassis with FPGA functionality is necessary (I do not know if cFieldPoint features this) in combination with a cRIO module or 2) a PXI chassis with a dedicated FPGA PXI card.
Basically one requires some I/O card or module supporting digital I/O and then either an DAQmx environment or an FPGA. The same goes to the flowscan issue.
(3,007 Views)
