Counter/Timer
Connect/Disconnect terminals PCI-6624
Hello Everybody, I'm currently using the "Connect/Disconnect terminals" vi to copy frequency signals between 3 PCI-6624 boards, with a RTSI cable between them.
Attached is a screen of my VI.
So, I have 3 PCI-6624 boards, named Cpt0, Cpt1, Cpt2.
I have 3 signals to copy, the first one (Shuttle) will be copied to 4 destinations.
The second one (Brakes) will also be copied to 4 destinations.
The third one (SeatSwitch) will be copied to 1 destination.
The 3 source signals are connected respectively to the Cpt0/PFI30, Cpt0/PFI27 and Cpt0/PFI35 lines.
Every source signal is 50 Hz, 25% duty cycle, but the phase is different.
Every time I have a rising edge on a boolean signal, I copy the 50 Hz signal on the destination, otherwise, the destination is connected to a blank PFI (=GND). I have no problems with the "Shuttle" and "Brake" groups, but the "SeatSwitch" has a random behaviour...
It seems like I cannot copy the SeatSwitch signal, without deactivating a copy of one other signal.
I have tried, in a blank VI, to copy or not copy (with the same method) the SeatSwitch signal with a boolean command and it works so I think there is no wiring problem.
I have also tried to make the changes in parallel, not with a For loop, but the problem is the same, it works with 2,3,4,5... copies but not with 9... Have you any idea of where my problem come from ?
I have been searching all day, any advice is welcome ! Thanks in advance.
(4,051 Views)
Hi Mattison,
It appears as though YannC addressed your issue in this thread.  Please post back if this did not resolve your issue.
David
Digital Multimeters
(3,958 Views)
