Counter/Timer
Capturing high speed encoder data
I have a motion control project where I would like to record position data. High speed capture is limited with 2Khz sample rate. But I have to record at much more higher speed.
I read that there was another option which is connecting the motion control card (I am using a PCI 7358) and the DAQ card by using a RTSI cable and routing the A and B channels of the encoder to the DAQ card using the RTSI lines.
I have 6143 and 6280 DAQ boards, PCI 7358 and a RTSI cable.
Q1. Which card is better to use? 6143 or 6280?
Q2. When I examine examples, I saw that its possible to route phase A and phase B signals of an encoder to the RTSI line with Signal Select.vi. But I couldn't find an example about how to read them from DAQ Card.
Q3. How could I obtain position information from encoder's phase A and phase B pulses which is acquired from DAQ card?
Regards
(6,108 Views)
Accepted by topic author serkanb
Hi serkanb,
The 6143 does not have support for quadrature encoder measurements (although you may perform an edge count task and use the B signal as an up/down line to get a similar effect).  If interested, more information can be found here (the 6143 uses the same STC I ASIC that the E Series DAQ devices do).
This doesn't really matter too much since you have a 6280 which does support quadrature encoder measurements (it uses the STC II ASIC).  To answer your direct questions:
Q1.  The 6280 is better (see above)
Q2.  You need to use a DAQmx Channel property node to select which terminals to use for your encoder task:
Q3.   I would start with a shipping example:
Help >> Find Examples... >> Hardware Input and Output >> DAQmx >>  Counter Measurements >> Position >> Measure Angular Position.vi
You would need to insert the property node before the Task is started (but after the channel is created).
I hope this helps, if you have any questions don't hesitate to post back!
Best Regards,
John Passiak
(6,099 Views)
