Counter/Timer
Baumer encoder attached to PCI 6024E
Hello all,
I have the Baumer encoder BHK 06 05A 1024-12-6 which I want to connect over the TBX-68 connector block to the NI PCI-6024E. The encoder should run in compementary mode. Do somebody know how to wire this up, please?
Message 1 of 8
(7,456 Views)
Hello all,
here is the connection table of the encoder. Hopefully somebody can help me now!? Its on page 3 the table "assignment cable for connection reference -5
05A (5 VDC complementary)".
Message 2 of 8
(7,446 Views)
Hello
As I understand you are after some information on wiring encoders, I have not been able to find a diagram specific to the PCI 6024E, but I have found some other resources which will help you.
The encoder has 3 channels, A, R and ZorN, the diagram on the following link is for a C series module, but it shows the pin configuration. The pins on your encoder are noted in the specification and are labeled A, B and N
Quadrature Connection Diagram
Connect Quadrature Encoders to a DAQ Device
Using Quadrature Encoders with E Series DAQ Boards
These resources give some diagrams and a number of instruction steps to help you set up the system.
Regards
Stephanie L
National Instruments UK and Ireland
Message 3 of 8
(7,438 Views)
Thank you.
Unfortunetaly, the link "Quadrature Connection Diagram" does not work. I will test the other two. They look very good to me. I have 6 channels on the device: A, B, N and A compl., B compl. and N compl. . What are the compl. for, please?
Greets
Message 4 of 8
(7,430 Views)
Hello
I am sorry that the link doesn't work for you. Here is the link to try again
http://digital.ni.com/public.nsf/allkb/E3918ED3AECB0DBA862577660058BFE8?OpenDocument
The compl. lines are complimentary lines and they produce a logical opposite of the signal, there is some further information available by searching online.
Regards
Stephanie L
Message 5 of 8
(7,426 Views)
Thank you. Your papers are very helpful to understand how the encoder works. Unfortunetaly the PCI 6024E card hasn't got these possibilities. I do not want to buy a new card because of that. Is it possible to get a binary code instead? For example when I would use in MAX the acire Signals → Digital Input → Port Input. How would I have to wire that up? When I search for "Port Input" in the tutorials I get a lot of nonsence ... .
Message 6 of 8
(7,416 Views)
Hi There,
Take a look at this tutorial. Is contains a section that I think you will find usefull titled "How to Make an Encoder Measurement".  Have a read on this section as it details how to wire up your encoder.
The following is another forum post that decibes your issue and has a potential solution here.
Hope these help,
Regards
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
Message 7 of 8
(7,400 Views)
Hey, thanks. The solution in the other forum looks nice. At the monent it does not work but I come closer to it. What is the "status" in the drawing about and how can I find it?
Message 8 of 8
(7,376 Views)
