Counter/Timer
6602 PCI
Hello Everyone, I am no expert in the field of electronics.
I have his older model 6602-PCI timer-counter (it was puschased back in 2001) for the fast multi-tau real-time correlator PCS (Photon Correlation Spectroscopy) DLS (Dynamic Light Scattering) application.
To upgrade the equipment, I need help from you to choose NEWER version(s) that can function the same but faster.
Thank you very much in advance for your support and comments.
(4,557 Views)
Before I make a suggestion, I have a few questions:
  1. Which functionality of the PCI-6602 is necessary for the correct operation of your application? For example, do you need 8 channels, or will 4 suffice?
  2. The PCI-6602 has a maximum source frequency of 80 MHz (125 MHz with prescalers). What is the maximum source frequency the upgraded hardware would need to handle?
For reference, here is the link to the hardware you currently have: https://www.ni.com/en-us/shop/model/pci-6602.html
Nick G.
Applications Engineering
(4,522 Views)
