Continuous Integration
G CLI 3.0 Breaking Changes
Hi All,
I'm finally getting some time on G CLI again. I know there is at least one crash to fix (https://github.com/JamesMc86/G-CLI/issues/106) which I will patch but then I'm looking to 3.0.
Currently slated for this is to achieve Linux support and STDERR support. There may be groundwork for STDIN but I think that will probably not make the 3.0 release.
To achieve this I'm also rewriting the front end in Rust. A language I'm more comfortable with and with simpler tooling which I hope will make me able to fix issues faster in the future.
The main reason for this post is I've noted a series of breaking changes for 3.0. I wanted to share this and get some feedback from anyone that has questions or concerns.
I've documented them here: https://github.com/JamesMc86/G-CLI/wiki/Version-3.0-Breaking-Changes please take a look and let me have any comments on this thread.
If you think there is something that is a breaking change that needs doing, also let me know now so I can include it in 3.0.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(4,991 Views)
I use G-CLI for my GitLab CI, it all looks good for me.
Great work by the way!
Epictetus
Antoine Chalons
(4,880 Views)
Hey James, you mention the timeout in your list of breaking changes:
The --timeout flag is now ambiguous with --kill-timeout. This will be deprecated in favour of a --connect-timeout flag.
What exactly will change (ie which parameter will be deprecated)?
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(4,862 Views)
Hi Joerg,
I plan to add the --connect-timeout as a replacement to the --timeout i.e. they would have the same function.
I think probably initially, we could just have both anyway to keep compatibility. I don't see any issue with this. But I have seem people get confused with which timeout the --timeout flag corresponds too.
James Mc
(4,855 Views)
Hey James--first thanks a ton for the work on this package. It's been incredibly helpful for my team in a number of ways.
Regarding the refactoring of the front end to use Rust, does this mean the C# portions of this tool are going to be deprecated? Can you provide some additional insight here please?
My concern here isn't regarding any breaking changes rather a persistent issue I have in automated builds of some of my applications which regularly fail due to the No Bytes at Port error (I'm the person who posted the ticket on your GitHub).
(4,825 Views)
Hi RkTrey,
Thats right. The C# code will be deprecated in favour of Rust. I'm hoping a side effect might be that we get some more useful information in this error case!
In fact I had to just test. The usual case for this error is if LabVIEW closes the connection improperly Normally due to a crash or the program stopping without calling exit.
The error in Rust shows:
ERROR [g_cli] ReadLvMessageError(Error { kind: UnexpectedEof, message: "failed to fill whole buffer" })
Still not a lot more helpful.
James Mc
(4,813 Views)
Hi James, like others, I want to thank you for your work on this tool.
Concerning the changes you plan to make, I can't see significant issues with my regular use of G CLI.
The most "problematic" thing for me is the minimum LV version. At some point, I will need to upgrade the minimum LV version supported by Antidoc and its CLI tool to stay up to date with G CLI 😄
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(4,784 Views)
