Components
Structured Error Handler Library
Hi Ryan,
Thanks for the answer! Good to know that I can dig into the code and see for myself what kind of risk may it carry, and what tests should I build around it to test it if I need to do so.
Message 81 of 117
(13,819 Views)
Hi there,
are there nay plans on implementing this lib on base of the Actor Framework? IMHO this would fit quite nicely
Best Regards
Oli
Message 82 of 117
(13,737 Views)
I've discussed it with Allen, and it's something we're planning to look into.  No ETA on it though.  Of course, the source is provided, so if you're feeling ambitious you could always take a crack at it 🙂
Ryan
Message 83 of 117
(13,730 Views)
I feared you'd make that DIY suggestion Smiley Wink
Message 84 of 117
(13,699 Views)
I just downloaded the latest version of the SEH and was using the "Repeating Error Handler" and CEH templates that ship with the SEH.  It looks like the "Priority" configured in the Express VI is incorrectly being compared to "Number of Notifications per Priority" as set in the CEH.
In other words:
1. In the CEH I have "Number of Priorities" set to 3.
2. In the CEH I have "Number of Notifications per Priority" set to 5.
3. The Express VI throws error 537602 only if I set "Priority" to 5 or more. I think it should throw an error if I set the "Priority" to 3 or more.
4. If I set the Priority in the Express VI to 0-2, the CEH responds as expected.
5. If I set the Priority in the Express VI to 3-4, the CEH doesn't do anything.
A couple of other things which are not bugs necessarily but really should be changed:
1. The Tip Strips for some of the controls in the Express VI Configuration Dialog box are misleading or incorrect.
2. The "VI to Call" input requires that the ".vi" extension be included. The Express VI should figure out to add the ".vi" extension if it is missing.
3. Since the "Loop?" output of the Express VI is TRUE when we WANT an iteration to occur, the Conditional Terminal of the While Loop in the "Repeating Error Handler" snippet VI should correspondingly be set to "Continue if TRUE" and not "Stop if TRUE".
Message 85 of 117
(13,461 Views)
The SEH express dialog lets you save error configs in xml files. Where should the files be saved, particularly when deploying to an RT target? Should the file then be added to the lvproj?
-Gary
Message 86 of 117
(12,775 Views)
The configuration for a given instance of the SEH node is stored within the scripted subVI that is created when you drop it.  The XML files serve as an easy way of creating templates for error behavior, for example, if you want to have the same or similar configuration in many different locations in your project (they also made my life much easier when I was testing it, as I didn't have to manually reconfigure the test cases every time).
There is no link between an SEH node and the XML that was used to configure it (important, as the XML files are not a way of slaving many different nodes to a central configuration, I considered that, but was unwilling to accept the deployment complications and performance tradeoffs it created).  To that end, you don't have to deploy the XML files in any way.  You can save them with your source and/or add them to your project for organization purposes.
Ryan K.
Message 87 of 117
(12,771 Views)
I would like to use the SEH to manage specific errors, but can it also be use to manage generic errors?  If I generate a managed error, it will be managed correctly, but if labview throw an error that is not manage in the SEH, the errors won't be catch by the Central error template.
How can I automatically classify unmanaged errors?
Thank you,
Message 88 of 117
(12,624 Views)
What happened to the link to download the SEH?   It appears to not be working.  Anyone know where I can get a copy?
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 89 of 117
(12,611 Views)
This seems to be a brower or OS specific issue. It may take us a couple of days to address this with the Thanksgiving holiday. Here are the direct links to the downloads from the page.
http://ftp.ni.com/pub/devzone/epd/seh_1_0_1.zip
http://ftp.ni.com/pub/devzone/epd/ni_seh-2.0.6.9.vip
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 90 of 117
(12,600 Views)
