Components
Simple Dual Redundancy Component
Please post your comments, questions, and feedback on the Simple Dual Redundancy Component here.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(8,663 Views)
Hi!
After reading the article, it seems that there is SDR device in between Active and hot standby Controller.
Since we are implementing dual redundancy so that we can recover from backup.
But what if the SDR fails and thus fails to provide dual redundancy to controllers.
Otherwise Article is good.
I am expecting a reply for this one:)
/ rtkrvj
(8,394 Views)
Hi rtkrv,
The SDR is a software-based implementation of redundancy and there is no extra device between the controllers (apart from the serial cable used for communication).
David H.
Systems Engineer
(8,384 Views)
Glad to see the reply:)
I have one more question regarding it, i.e.
In normal state, input to both the control units will be there and only failure of a primary control unit, secondary control unit starts sending the output.
Correct me if I am wrong.
Now my question is that do we need to have an I/O processor unit to send input to both control units at every instant?
eg:
Sensors>>IO processor Unit>>Primary Control Unit>> output
>>Secondary Control Unit
If Primary Control Unit fails, then
>>Secondary Control Unit>>output
Here, fault tolerance is done on Control Unit, but what if the IO processor unit fails?
Please revert in case of clarification.
Thanks, 🙂
/ rtkrvj
Message Edited by rtkrvj on 04-18-2009 02:29 AM
Message Edited by rtkrvj on 04-18-2009 02:30 AM
Message Edited by rtkrvj on 04-18-2009 02:31 AM
(8,375 Views)
